Forums >> Revit Systems >> Technical Support >> Applying Electrical panel schedule templates in 2011
Thu, Sep 9, 2010 at 11:17:50 AM | Applying Electrical panel schedule templates in 2011
jbatka
I have recently updated a 2009 Revit project to 2011. When using 2009, the panel schedules were rather crude, so we did not use them. Since the panel schedule updates in 2011, I thought I would try to use the new features.
 Here is the issue I am having:
In 2009, all the panel schedules were typical (two-columns)
In 2011, I would like to change the schedule from (two-columns) to (one column). The problem with this is when I try to update the old panel schedules, it doesn't give me the option to switch from (two-columns to one-column).
Is there any way around this? Any help would be appreciated!
I really thought the new features (panel schedules) were going to be a great asset to the program, but so far I am just having more issues. If this problem can't be solved, looks like excel is still the way to go...
Thanks,
Jeff
electrical panel schedules in 2011
Fri, Oct 22, 2010 at 12:11:22 PM
Custom MEP Electrical Panel Schedule
Fri, Jul 13, 2012 at 1:45:21 PM
Panel Schedule help
Fri, Jul 19, 2013 at 12:56:51 PM
Tue, Sep 14, 2021 at 9:18:20 AM
adding existnig loads to electrical panel
Tue, Feb 23, 2010 at 9:32:02 AM
Page generation time: 3.6391
