Forums >> Revit Building >> Technical Support >> Wall shading
Mon, Oct 17, 2005 at 12:38:35 AM | Wall shading
David Ewing
I would like to see the layers of my new and existing wall assemblies in Medium/Fine detail view in plan while I am working on them, but switch to Coarse view before printing. In Coarse view, I would like new walls to be shaded grey in plan, and existing walls to be white. If possible, I would like to avoid having 2 of each wall type, one shaded and one white. I thought I had this worked out with the Phase overrides and Phase Materials, but it doesn't seem to work as I expect.
Mon, Oct 17, 2005 at 3:03:48 AM | RE: Wall shading
eldados
eldados Avatar
4.5 Stars: 8 Votes
you need to control it from the wall properties, define the coarse pattern or shade you want...
Integrator
KarelCAD
Mon, Oct 17, 2005 at 6:00:16 PM | RE: Wall shading
David Ewing
I can do this, but I want the same wall type wall to appear differently if it is existing than if it is new. The override does not work as expected; I can get the exist. white in New Const Phase but in an Existing Phase view, it is shaded. (Same Filter: Show All.)
Wall Materials and shading.
Fri, Jan 30, 2009 at 4:01:22 PM
New wall trasparent shading.
Thu, Jun 15, 2017 at 7:46:15 AM
Shading Toolbar
Tue, Jun 22, 2004 at 9:54:36 PM
Mesh Sun Shading Device
Fri, Apr 16, 2010 at 1:52:54 PM
TOO DARK Shading with Edges Revit 2009
Mon, Aug 25, 2008 at 6:57:19 PM
11
Page generation time: 2.8537
