Forums >> General Discussion >> Wishlist >> PRINT RANGE SETS BY PARAMETERS
Thu, Sep 9, 2010 at 9:41:40 AM | PRINT RANGE SETS BY PARAMETERS
BDerrick
3.5 Stars: 3 Votes
I wish that you could filter sheet sets in the print dialog by sheet parameters.  What if you wanted to print all sheets from issue date X and not issue date Y?  Or, what if you wanted to print all the sheets with revisions?  Schedules update automatically when new sheets are added to fit the filters but sheet sets do not. Revit is really good at eliminating user error but this is a big drawback.
Thu, Sep 9, 2010 at 9:57:24 AM | PRINT RANGE SETS BY PARAMETERS
Pretty simple process.  Why don't you set up a working schedule to filter your sheets and then print what the schedule lists?
Thu, Sep 9, 2010 at 11:34:57 AM | PRINT RANGE SETS BY PARAMETERS
BDerrick
3.5 Stars: 3 Votes
Right, that's how we're doing it now.  But, like I said before, there is always user error.  You can set up a sheet set but if you rely on it too much you'll miss sheets that have been added recently.  When you have hundreds of sheets it becomes time consuming to match your print set to the schedule.  For multiple issues of the project set it's even worse.
Wed, Feb 23, 2011 at 11:15:12 AM | PRINT RANGE SETS BY PARAMETERS
col9000
Hi... I know this is an old thread, but just wondering if it's possible to automatically select drawings for printing based on what is listed on a schedule? Or is it just a case of looking at the schedule and ticking the boxes for the appropriate sheets, then saving the set (i.e. the set is not responsive to the addition of new sheets)
Wed, Feb 23, 2011 at 12:02:30 PM | PRINT RANGE SETS BY PARAMETERS
BDerrick
3.5 Stars: 3 Votes
That's exactly what I was hoping for as well.  It seems as though, at the moment, you have to manually choose the sheets you want in the print set dialog box.  I requested an add-in from the awesome programmers at http://www.revitappstore.com/.  They gave me a glimpse of what the add-in could do (it allows you to select sheets based on sheet parameters, allows you to name the print set, but doesn't create the print set).  This was a quick app they made unfortunately they asked too much for the full add-in.  I've told them that I think a lot of people would be interested.  If you're interested let them know: http://www.revitappstore.com/contact.php?AppId=29
Edited on: Wed, Feb 23, 2011 at 12:03:21 PM
Wed, Feb 23, 2011 at 12:19:44 PM | PRINT RANGE SETS BY PARAMETERS
If you ned to update a set, then use it as a base, add - subtract as you need then save.
Wed, Feb 23, 2011 at 12:56:06 PM | PRINT RANGE SETS BY PARAMETERS
BDerrick
3.5 Stars: 3 Votes
But I've already done that in my schedule so it can appear in my sheet index.  Why should I have to do it again?  It's always a time crunch when it comes to printing.  And having to check a few hundred sheets more than once isn't efficient.
Print Range Locked
Tue, Oct 28, 2008 at 2:11:30 PM
Titleblocks
Tue, Aug 2, 2005 at 5:36:17 PM
Print range.
Tue, Jan 31, 2017 at 2:45:30 AM
printing sheet sets - only the sheets
Wed, Jul 18, 2012 at 3:10:10 PM
Option Sets displayed together?
Wed, Apr 2, 2008 at 9:36:13 AM
Page generation time: 0.2383
