Forums >> Revit Building >> Technical Support >> Copy/array an extrusion in the "depth" direction
Thu, Sep 9, 2010 at 8:57:12 AM | Copy/array an extrusion in the "depth" direction
JeroentjeM
Hello,
I have created an extrusion which represents a wooden beam. I draw the sketch, which determines length and heigth. The thickness of the beam is the depth of extrusion.
The beauty of the array would be, that the length is variable, and the angles adjust automatically. Now I want to array this beam, so multiple beams with this shape are next to eachother. Here comes the problem, I can't copy into this direction? I can only copy in the directions of the sketch, height and length...?
Any other options? I've tried to create the beam as a line-based model, create a reporting-parameter to determine it's length, and tied the length of the beam to the reporting parameter, but once the reporting parameter changes, the beam length doesn't....
Argh? I'm running out of ideas...Anyone? Thnkx!
Thu, Sep 9, 2010 at 8:58:37 AM | Copy/array an extrusion in the "depth" direction
JeroentjeM
Images...
Thu, Sep 9, 2010 at 9:20:14 AM | Copy/array an extrusion in the "depth" direction
JeroentjeM
File...
Thu, Sep 9, 2010 at 9:53:49 AM | Copy/array an extrusion in the "depth" direction
JeroentjeM
the reporting parameter:
Thu, Sep 9, 2010 at 10:37:01 AM | Copy/array an extrusion in the "depth" direction
JeroentjeM
option with reporting parameter
Thu, Sep 9, 2010 at 11:57:10 AM | Copy/array an extrusion in the "depth" direction
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I'm not exactly sure what your objective is but this looks like a job for the 'Beam System' tool ?
2-dimensional Array of Arrays
Wed, Aug 3, 2011 at 7:47:12 AM
Joining Roof By Extrusion
Mon, Jan 31, 2011 at 8:15:14 AM
Help needed to Align a Filled Region to a "family" (Deck Span Direction)
Mon, Jan 14, 2008 at 12:38:56 PM
When I copy an "existing" element it reverts back to "new construction."
Mon, Jun 16, 2008 at 2:38:24 PM
Mirroring entire project- "copy" check box greyed out?
Sun, Apr 23, 2006 at 6:44:57 PM
Page generation time: 0.9229
