Forums >> Revit Building >> Technical Support >> How do one create custom, adjustable curtain wall panels?
Wed, Sep 8, 2010 at 9:21:10 AM | How do one create custom, adjustable curtain wall panels?
bengtm
3 Stars: 2 Votes
I'm trying to create a possibility to easily make corrugated metal walls. This I was going to do via a curtain wall.
 Although, it seems as if I'm not skilled enough, so I will need som help.
I wonder what way i should go? I've been trying to create a "Curtain Wall Panel", but I don't know how to make it auto-adjustable in height? which seems to be the biggest problem atm..
 If anyone could help or give me some guidlines it would be awesome.
Wed, Sep 8, 2010 at 9:42:43 AM | How do one create custom, adjustable curtain wall panels?
narrsam
Hello there;
Can you state the version of revit you're using?
Wed, Sep 8, 2010 at 9:55:51 AM | How do one create custom, adjustable curtain wall panels?
I would never model corrugated wall panels because you will overload your model.  We use a material type to render them and use a pattern for elevation views.
Thu, Sep 9, 2010 at 2:32:04 AM | How do one create custom, adjustable curtain wall panels?
bengtm
3 Stars: 2 Votes
I'm using Revit 2011.
WWHub do you have a useable material-picture that you might want to share?
 It would be nice to be able to do it, as it won't be used in any huge-scale projects and therefore the computers will be able to handle it to a certain limit.
Thu, Sep 9, 2010 at 4:59:36 AM | How do one create custom, adjustable curtain wall panels?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Doesn't the curtain panel just fill the curtain grid to achieve it's height and width ?
Thu, Sep 9, 2010 at 6:27:37 AM | dgcad
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting dgcad from 2010-09-09 04:59:36
yes it does. all he has to do is design the new curtain panel
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Sep 9, 2010 at 9:15:52 AM | How do one create custom, adjustable curtain wall panels?
mansell5
3.5 Stars: 4 Votes
check out this blog to design your own profiled roof sheet.
http://revitfamilies.blogspot.com/
shaun uses a spandeck type profile but it should give you a few pointers.
cheers
Thu, Sep 9, 2010 at 10:00:39 AM | How do one create custom, adjustable curtain wall panels?
For metal sidings, I have used texture bitmaps I found on this site: http://steelselect.com/content/viewresource.php?id=4284search.results.php
Thu, Sep 9, 2010 at 10:22:36 AM | How do one create custom, adjustable curtain wall panels?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Same.
Curtain wall custom panels "FLIP"
Mon, Feb 18, 2008 at 5:30:43 PM
Inserting Custom Curtain Panels Into Angle/skewed
Fri, Apr 30, 2010 at 4:50:44 AM
Curtain wall panels following profile
Wed, Oct 12, 2011 at 8:41:57 AM
Can Curtain Wall Panels and Sloped Roofs
Wed, Jul 2, 2014 at 12:51:49 PM
Add logo to to curtain wall panels
Fri, Jun 14, 2013 at 9:05:52 AM
Page generation time: 2.7127
