Forums >> Revit Systems >> Technical Support >> color scheme disappear
Tue, Sep 7, 2010 at 6:29:08 PM | color scheme disappear
mudan
hi guys. i have been working on a file and set up color scheme by Room Name, which been well working but yesterday, after i did some minor changes with grids and familys, i realised my color scheme has disappeared. if i click color scheme and drop in to my drawing, the legend still correct but just no color showing in any of the rooms. any one have any idear? thanks in advance.
Wed, Sep 8, 2010 at 7:14:58 AM | color scheme disappear
Whenever something no longer shows and it used to, there are normally two areas you should check first.  First is Visibility Graphics, VG - Is color fill on?  Are Rooms on?  In other cases, the second thing normally to check is if the item is hidden in view.
Also, Learn to use your HELP.
Fri, Sep 24, 2010 at 7:49:22 PM | color scheme disappear
mudan
Thanks for reply. my vg and other settings is right. and i found my color is actually hide by the slab. is there any way to keep my slab in the view and also the colors? thanks
DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011 [ 1 2 ]
Sun, Jan 13, 2013 at 11:26:10 AM
29
Revit 2014 - Color Schemes disappear when zooming
Tue, Oct 29, 2013 at 5:00:31 PM
new color scheme entry error
Thu, Sep 18, 2014 at 1:42:54 PM
12
Color Scheme Legend Issues
Mon, Dec 1, 2014 at 6:26:38 AM
Color Scheme Problems
Tue, Jun 26, 2007 at 11:53:16 PM
Page generation time: 0.5334
