Forums >> Revit Building >> Technical Support >> Exterior Door Help
Tue, Sep 7, 2010 at 9:00:56 AM | Exterior Door Help
bushbenjamin
I've got a custom exterior door that I'm working on and I was hoping someone could identify the problem I'm having with it.
 When I bring the door into a project, everything is visible and copacetic in the floor plan views and the 3-D views, but when I switch to the elevation, the panel is showing up but none of the glass/grids.
 I've checked to make sure the visibility settings are correct, but I can't seem to find the problem. Can anyone shed some light on the mistake?
Tue, Sep 7, 2010 at 9:33:23 AM | Exterior Door Help
4 Stars: 205 Votes
In project change the "Coarse" mode to "Medium/fine" mode view, this solve the problem?
Tue, Sep 7, 2010 at 9:51:13 AM | Exterior Door Help
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Also, you may want to open the door family and check the visibility settings of the grid / glass. They are probably turned on in 3D but not in Front / Back (elevation).
Select the problem sub components then clcik the visibility graphics override button on the properties palette.
You can also change the settings Ty has suggested from this same dialog box.
See attached image of visibility settings within the window family.
Tue, Sep 7, 2010 at 1:25:01 PM | Exterior Door Help
bushbenjamin
Thanks dgcad, you were correct. I was able to fix the problem.
Revit only showing me one door type; flush door
Sat, Nov 17, 2012 at 6:31:39 PM
Walls change when door is inserted
Thu, Oct 30, 2014 at 9:04:42 PM
Door Swing Direction
Thu, Sep 23, 2010 at 8:10:26 AM
Zero threshold door.
Thu, Oct 24, 2024 at 11:50:45 PM
Getting door elevations
Thu, Nov 21, 2013 at 6:12:08 PM
Page generation time: 0.5119
