16 Users Online (14 Members):
Forums >> General Discussion >> Revit Project Management >> exporting material library to another revit model?
10 Posts No Rating |
hey all, i need to export one material library from one revit model to another, how can i do this in revit 2011? thanks in advance, tom
Did you try to open the two projects, then select a simple component with that material (a wall for example), then CTRL-C, go to the new project and CTRL-V, it's a simple copy/paste, also, in Manage tab you have "Transfer Project" where you can transfer what you want from one project to the other, in this case select only "Materials".
0 Posts No Rating |
may I export a material library of revit 2013 in order to open the same material library in revit 2014?
thanks
0 Posts No Rating |
In the Manage tab, go to transfer project standards and select MATERIAL. Im not sure you can do it in the 2011 version but I think so.
How do you add an imported material to Revit's material library ? |
Mon, Aug 16, 2010 at 8:06:17 AM
Question about shared custom material library |
Wed, May 18, 2016 at 6:44:31 AM
Material library |
Fri, Mar 3, 2006 at 9:11:37 AM
Exporting Revit 9.1 Model to 3ds Max, Material Issues |
Tue, Oct 16, 2007 at 10:38:26 AM
Help me! Lack of BMCD2AR3 material library in revit building 8. |
Sat, Oct 8, 2005 at 9:54:16 PM
