Forums >> Revit Building >> Technical Support >> Counting Polygons and Vertices in Revit family object
Sat, Sep 4, 2010 at 8:24:01 PM | Counting Polygons and Vertices in Revit family object
LaCucha
Hello,
I need to count the polygons and vertices in my Revit Family Object.  Does anyone have any nifty tips how to do this?  Do I have to browse through my Revit family and manually count them?  If so, how do I do this?  Questions, questions.
Thanks in advance!
Fri, Sep 10, 2010 at 2:40:28 PM | Counting Polygons and Vertices in Revit family object
WongWa
WongWa Avatar
2 Stars: 4 Votes
export to 3Ds Max and it will give you that number..
revit does not give you that number as far as i know..
Leader Lines: Adding vertices?
Fri, Feb 23, 2007 at 1:44:48 PM
Revit 2018.2 Print to PDF Turning Curves into Polygons
Tue, Apr 17, 2018 at 12:30:39 AM
walkthrough counting numbers on the right top of the image
Fri, Sep 12, 2008 at 6:31:39 PM
Revit double counting objects in Schedule
Mon, Apr 13, 2009 at 1:58:19 PM
is there any way to transfer family object to instance object or something like
Wed, Jun 1, 2011 at 7:10:55 AM
Page generation time: 4.2320
