Forums >> Revit Building >> Technical Support >> Pocket window
Sun, Oct 16, 2005 at 9:54:55 AM | Pocket window
Molonesh
Hello, I want to create a family of windows with pockets in the wall. I have tryed to trensform a pocket door I found here but the didnt exept it. Can some one help me either with a pocket window or with the procedure? Thanks in advance
Sun, Oct 16, 2005 at 6:11:31 PM | RE: Pocket window
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Begin with a fresh window template. Delete any unwanted trims/parameters. Delete the opening cut... Place reference planes to setup the extents for the cuts to the wall. Create a void to cut the opening and recess into the wall. Use the Cut geometry tool. Select the void then the wall. Now start modelling your window.
Glider Window in pocket
Wed, Oct 2, 2013 at 7:03:59 AM
Problem creating a pocket
Thu, Feb 7, 2008 at 2:14:32 PM
Pocket doors?
Sat, Jan 5, 2008 at 5:19:04 PM
I am looking for a pocket, double side window. Where can I find it? thanks
Wed, Jul 20, 2005 at 8:05:01 AM
Pocket doors
Fri, Jan 26, 2007 at 1:39:39 PM
Page generation time: 2.0452
