Forums >> Revit Building >> Technical Support >> Dimensioning with text
Wed, Sep 1, 2010 at 9:21:56 AM | Dimensioning with text
ESCOZA
5 Stars: 2 Votes
When adding text to a dimension, I noticed that the below box places the text 2 spces down. Can this be adjusted?
Wed, Sep 1, 2010 at 9:29:47 AM | Dimensioning with text
All your dimension options are in your dimension setup and I don't see anything.
Wed, Sep 1, 2010 at 9:37:03 AM | Dimensioning with text
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Try adjusting the "Text Offset" in the Type properties of a Dimension. This value adjusts how far the text is placed off the Dimension Line.
How do you handle dimensioning not-to-scale stuff in Revit?
Mon, Aug 15, 2011 at 2:30:05 PM
Dimensioning to the centerpoint of an arc
Tue, Jul 29, 2008 at 4:11:55 PM
Overwriting Dimension with Text
Thu, Jan 11, 2007 at 11:13:56 AM
Need help dimensioning this wall!
Sat, Jul 25, 2009 at 10:56:26 PM
DIMENSIONing GRIDS - on plan view
Thu, May 26, 2011 at 1:33:19 PM
Page generation time: 0.2108
