Forums >> Revit Systems >> Technical Support >> revit 2010 has stopped working
Wed, Sep 1, 2010 at 7:18:34 AM | revit 2010 has stopped working
dirk
to whoever can help!!
hey guys my revit architecture 2010 just refuses to start. we run on windows 7 64bit. if i create a new user acount it works fine but when i try to start it in my old user account the the picture comes up and after a couple of seconds another window pops up which says revit has stopped working!
is there a solution to this other than a clean uninstall?
regards
dirk
Wed, Sep 1, 2010 at 7:29:39 AM | revit 2010 has stopped working
Not sure about the path but in your local settings, find :
\Application Data\Autodesk\Revit\\Autodesk Revit Architecture 2010\ENU\Components\WebServices\WSCommCntrData.xml
Rename that xml file - maybe just add old on the front of it.  You could just delete it but you may be afraid to.  Revit will rebuild this file and all will be ok.
Edited on: Wed, Sep 1, 2010 at 7:31:58 AM
Wed, Sep 1, 2010 at 10:29:22 AM | revit 2010 has stopped working
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Excellent suggestion Hub as that has been causing a lot of issue in 2010.
Another thing you may try is that this seems to be "profile" specific is reset your ribbon interface.
Easy to do, just browse to almost the same location that Hub gave you and delete the UIState.dat file there.
 Here is an example of the location on my computer:
C:\Documents and Settings\goodchildb\Local Settings\Application Data\Autodesk\Revit\Autodesk Revit Architecture 2010
It is safe to be deleted and is recommended by Autodesk.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Wed, Sep 1, 2010 at 12:54:02 PM | revit 2010 has stopped working
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I just got this exact error myself today, right out of the blue. . RAC 2011 64bit.
Yet RST 2011 had no problem.
Searched and then renamed the WSCommCntrData.xml file and not only does REVIT now start it starts up MUCH QUICKER !
So the Splash Screen is what's slowing down the startup . . . . go figure.
I figure it must be related to a recent Windows update.
Wed, Sep 1, 2010 at 1:08:20 PM | revit 2010 has stopped working
Bimman
Bimman Avatar
1 Stars: 2 Votes
we had one system do that about 2 weeks ago, we deleted the WSCommCntrData.xml file and it was fine. started right up. don't how the file was corrupted, we did nothing any different from the other 9 seats we are running.
PWD
Wed, Sep 1, 2010 at 1:31:43 PM | revit 2010 has stopped working
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Weird. . . I agree.
Came right out of the blue. Actually now that I think of it . . . . recently installed Google Earth + Chrome . . . . hmmm
Before I renamed that file I did a video card update which was available at microsoft but that didn't do anything but scatter my desktop icons.
So, I noticed it did not recreate that xml file so you have to wonder what was it for and how come we can simply eliminate it without any impact?
Wed, Sep 1, 2010 at 1:49:12 PM | revit 2010 has stopped working
Bimman
Bimman Avatar
1 Stars: 2 Votes
i tracked ours back to a storm we had the day before which was a direct hit on our building.  lost power for 5 hours and elevator for 5 days... not fun when you work on the top floor.  Anyway the next day when he went open it would not work.  but everybody else was fine.  not sure but that was the moment i cold go back to.  But after we deleted and reopened it put a new file with the same name in its place. so ours was recreated upon restart of not having one there.
PWD
Wed, Sep 22, 2010 at 12:04:26 AM | revit 2010 has stopped working
jimsarr
uninstalling that UIState.dat  file worked for me!  thanks so much!
Sat, Jul 2, 2011 at 11:31:12 PM | revit 2010 has stopped working
JOHNCCOLE
Yayuh!
Altho this post is from years past, just wanted to say THANKYOU. No help from AutoDesk, so when I searched here, i not only foiund a description of my problem, but I also found the answer!
You guys are awesome.
mojo
Wed, Apr 3, 2013 at 9:31:29 AM | revit 2010 has stopped working
aggiealecs
3.5 Stars: 8 Votes
Thanks guys! I'm running Windows 7 and was suddenly having the same issue. Deleting the WSCommCntrData.xml file worked for me.
Revit 2015 has stopped working.
Mon, Oct 27, 2014 at 1:57:47 PM
Spell Check stopped Working
Mon, Oct 5, 2015 at 6:38:39 PM
CutePDF stopped Working. Any alternatives?
Mon, May 3, 2021 at 7:35:28 AM
Revit Architecture 2010 thumbnails not displaying
Tue, Dec 28, 2010 at 1:59:06 PM
alt keycodes not working in 2010
Tue, Sep 8, 2009 at 3:40:56 PM
Page generation time: 2.6023
