Forums >> Revit Systems >> Technical Support >> Linking Other Models
Tue, Aug 31, 2010 at 9:46:29 AM | Linking Other Models
koolair
4.5 Stars: 2 Votes
Good day everyone,
I am faced with a strange scenario.  I am linking in a bunch of architectural models into a new project, but the links do not show up.
They show up on the list under FILE-->MANAGE LINKS, but there is nothing in my host model.  I went to a 3D axonometric view, and still no dice.
Before linking in, I made sure I went into each architectural model (detaching from central before opening), removing all the overlays, purging, and saving.
This is very bizzarre.  Hope someone can help!
Joe
Tue, Aug 31, 2010 at 10:20:53 AM | Linking Other Models
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Is it possible the linked models are outside the 2d crop region or 3d section box?
Ho did the models get initially positions Auto-center to center, Manual - base point etc....
Tue, Aug 31, 2010 at 11:00:51 AM | Linking Other Models
koolair
4.5 Stars: 2 Votes
I'm linking using "auto - origin to origin"
I have extended the viewing range high and wide.
Thanks for replying
Joe
Tue, Aug 31, 2010 at 11:30:27 AM | Linking Other Models
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Try turning off the crop region and zoom all to fit.
Do the same with 3d and section box.
Check for Scope boxes?
 Check Phases?
Check Worksets?
Then move to visibility graphics oveerrides.
It's there, you just have to find it.
Edited on: Tue, Aug 31, 2010 at 11:32:40 AM
Tue, Aug 31, 2010 at 12:04:02 PM | Linking Other Models
koolair
4.5 Stars: 2 Votes
aha!
That's awfully strange.  My default template has level 1 located waay below the architectural model's L1.
That was great dgcad.  Thanks for that tip.  Just out of curiosity....will this base level be different for other architects?
Thanks
Joe
Tue, Aug 31, 2010 at 1:35:54 PM | Linking Other Models
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Yes, it will definately vary.
Linking the Autodesk Advanced Models Together
Mon, May 19, 2014 at 2:02:04 PM
Linking models with multiple sites
Wed, Dec 6, 2017 at 9:43:09 AM
linking models into models
Fri, Aug 24, 2007 at 12:55:28 PM
linking models via origin to origin problem
Wed, Sep 30, 2015 at 10:20:09 AM
Linking Models
Wed, Mar 5, 2008 at 3:22:34 PM
Page generation time: 2.1976
