Forums >> Revit Building >> Technical Support >> hidden lines in structural
Sat, Oct 15, 2005 at 8:32:49 PM | hidden lines in structural
sydneysider
easy one this I guess I'm trialing the Structural release & must say v impressed Now one thing is driving me mad If I have a panel of RC beams & slabs, the only way I can get the hidden view of the structure is to move the slabs up (or beams down) a fraction - not ideal - and I suspect its me, not the software.
Sat, Oct 15, 2005 at 11:58:58 PM | RE: hidden lines in structural
joshb416
Hey, Try looking under the View Range setting in the View property dialog box and changing the cut plane. JB
Mon, Oct 17, 2005 at 7:15:08 PM | RE: hidden lines in structural
sydneysider
thankyou JB I have had a play around and see the possibilities in the VP dialogue now I have yet to see a pattern though that gives me consistant reliable results All slabs are 225 thk, all RC beams are 600 deep - to create a simple outline with beams & column head heads dotted I though my settings should be Top Offset 10, Cut Plane 10 (ie above the slab so their is no cut linestyle for the beam, Bottom offset -600) - I'll keeep trying though & thanks for your help SS
Tue, Oct 18, 2005 at 4:20:53 AM | RE: hidden lines in structural
sydneysider
Still no luck So I've attached a file with 2 very simple arrangements in it - plus some text to explain my difficulties any help would be much appreciated - I'm sure it's a me thing! SS
Wed, Oct 19, 2005 at 8:58:55 PM | RE: hidden lines in structural
antfa
Hi, Try using the linework command type "LW" and select the lines to change to hidden etc, you can adjust the length of the line with its grips. Regards Anthony
Wed, Oct 19, 2005 at 9:14:35 PM | RE: hidden lines in structural
sydneysider
antfa Thank you very much - that's just the job! - i knew it would be easy & how simple it turned out to be SS
Wed, Oct 19, 2005 at 9:16:54 PM | RE: hidden lines in structural
antfa
no worries, I struggled with the same problem a few days ago Cheers Antfa
Show Hidden Lines - Structural Foundations
Thu, Jan 13, 2011 at 10:37:01 AM
how do you make structural beam systems visible.
Fri, May 8, 2009 at 4:34:31 AM
Show hidden lines
Wed, Apr 16, 2008 at 5:52:55 PM
Structural link showing colored lines - please help!
Thu, Dec 2, 2010 at 3:32:36 PM
Show Hidden Lines Tool and Detail Elements
Fri, Nov 22, 2013 at 8:48:50 AM
Page generation time: 4.0176
