21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Show brickwork only
18 Posts No Rating |
Hi RevitCity Citizens! I have a question hoping there is an easier answer than I can see. I am currently in 2010, upgrading in a couple of weeks. I have to do set out drawings for brickwork, and the complication is that there are a number of walls that are both brick and stud. Is it possible to show ONLY the brickwork? (withouth going back and separating the walls and drawing them "double" cheers
Hello mysterious smiley face
Your answer is seperate walls or in the plan where you only want the brick, you use the hidden line tool on the stud portion.
Shaded brickwork in elevation |
Mon, Jun 25, 2012 at 8:03:58 AM
Shading Brickwork |
Wed, Jul 18, 2012 at 1:53:28 PM
Cavity closer - only closes on brickwork |
Fri, Nov 9, 2007 at 4:37:59 AM
Brickwork Feature around a Window |
Sat, Jul 19, 2008 at 8:51:46 AM
How Do I Create A Lean To Roof Over A Garage |
Thu, Jan 15, 2009 at 3:28:43 PM
