28 Users Online (26 Members):
Forums >> Revit Building >> Tips & Tricks >> Revit TotD - 8.30.2010 | Controlling your Demolition In-Fill Types
An easy quick tip to start off the day. Phasing can be a pain to even the most seasoned Revit veterans, and hopefully I can help you out with a little in-fill issue you may have in the future. When you demolish a door, window or any wall cutting object out of a wall, it replaces that former opening with an in-fill wall. This wall has no phase information but can be replaced with ANY wall type you have already defined. If you have a scenario where you want to replace the in-fill area with a different wall type (say you have a CMU/Concrete building and just want to in-fill with stud walls), this tip is going to be right up your alley! - Demolish your wall cutting object
 - In your next phase view, select the in-fill create by the previous demolition.
 - Choose the wall type you wish to use.
 - Choose the location line alignment.
 - Voila! Quick, easy and painless!
As always, you can view this tip in its entirety at http://revittotd.com/08/1029. Thanks for stopping by and please feel free to leave feedback! -Carl Gibson
Edited on: Mon, Aug 30, 2010 at 9:05:28 AM
Revit TotD – 6.30.09: Room Tag Types “I don’t have that option!” |
Tue, Jun 30, 2009 at 5:14:23 PM
Revit TotD - 8.26.2010 | Quick Plan Perspectives (via View Cube context menu) |
Thu, May 31, 2012 at 3:02:54 PM
Revit TotD – 2.19.10 | Dimension Formulas |
Fri, Feb 19, 2010 at 10:29:46 AM
Revit TotD – 7.30.09: Revit 2010 Add-In Manager |
Thu, Jul 30, 2009 at 7:08:14 AM
Revit TotD – 2.24.10 | Render Texture Alignment |
Wed, Feb 24, 2010 at 9:10:30 AM
