Forums >> Revit Building >> Technical Support >> ELLIPTICAL STAIR
Sun, Aug 29, 2010 at 4:42:28 AM | ELLIPTICAL STAIR
Kelee
CAN YOU ANYONE SHOW HOW TO MODEL ELLIPTICAL STAIRS?
MUCH APPRECIATED FOR THE HELP.
Sun, Aug 29, 2010 at 10:10:26 AM | ELLIPTICAL STAIR
An elliptical stair can be drawn the same as a straight stair using the line tools under the stair construction tab.  NOTE:  You will have to use simple arcs to create your ellipse.  I know this is an approximation of an ellipse but I really prefer this because you can dimension this and then the contractor can actually build this.  A true ellipse is very hard to build in the field and I don't think anyone can really see the difference.
Edited on: Sun, Aug 29, 2010 at 10:10:53 AM
Sun, May 15, 2011 at 7:07:59 AM | ELLIPTICAL STAIR
SJkachmar
I am using 2012 and there is still no Elliptical option for creating Stairs!? I am trying to model Elliptical Residential Stairs to be built on a CNC machine. I need the stairs to be exact.
 Are People using Inventor, or 3DS max to model stairs for this stuff? or is there a way to do this in Revit that I am not seeing?
  Please help
 "Wherever you go, there you are"
Sun, May 15, 2011 at 8:27:40 AM | ELLIPTICAL STAIR
coreed
coreed Avatar
4 Stars: 16 Votes
i would suggest that you try the Conceptual Mass modeller. but you will have to  totally model your stair. which i would assume would be the same with Inventor, 3d Max etc. But you know what they say about assuming.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Elliptical sloped roof in Revit
Thu, Jan 23, 2014 at 6:01:52 PM
Elliptical concrete columns
Tue, Aug 15, 2006 at 5:46:28 AM
Elliptical stairs help
Thu, Sep 1, 2011 at 10:15:49 PM
14
Stairs and Railings Of Course
Fri, May 24, 2013 at 9:41:23 AM
Parametric elliptical shape in family
Fri, Feb 20, 2015 at 4:30:19 AM
Page generation time: 0.1313
