10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> please help with my title block
3 Posts No Rating |
i have been trying to make a title block in v.2011. everything seems to be fine until i try to insert the project address. i go to: HOME> LABEL> click anywere for the EDIT LABEL Window> select "Project Address" > click ADD PARAMETER(S) TO LABEL> APPLY> OK> then move the text to were i want it. i edit the type and then> in the MODIFY/LABEL tab i select LOAD INTO PROJECT. next i go into the central file for the project and click OVERWRITE THE EXISTING VERSION AND UPDATE PARAMETERS. all of the titleblock elements are there and o.k. except for the address, it says "Enter address here" but when i click on it the entire title block is highlighted instead of an editing window appearing like everywhere else. if i go back and switch "Poject Address" with another label everything works fine. what am i doing wrong?
You can find a lot of useful advice here on RC searching past threads. Also look at the similar threads that are posted below your posts. One of those has this advice from corred to look at this thread:> http://www.revitcity.com/forums.php?action=viewthread&thread_id=6548 I think you will find your answer there.
go to Manage>Project Information and change the address there
Macca Sunshine Coast QLD Australia |
Font on Title sheet absent from project Title Block |
Thu, Sep 15, 2022 at 12:31:26 PM
How to import my title block from AutoCAD? |
Mon, Sep 10, 2007 at 4:25:43 PM
12
In the default Revit Templates i couldnt find revit title block |
Fri, May 23, 2014 at 7:22:23 AM
How to link a Revision Schedule on Title sheet with Title Block |
Fri, Jan 11, 2013 at 7:26:26 AM
project title block |
Tue, Dec 1, 2009 at 2:18:45 PM
