Forums >> Revit Structure >> Technical Support >> Detaching from Central Model...I CANT!
Thu, Aug 26, 2010 at 4:22:27 PM | Detaching from Central Model...I CANT!
gregroberson
gregroberson Avatar
I am trying to detach a model from centralto give the model to our Architect...or to experiment in the project.  But even when I hit the "detach from central" radial box, then save...and reopen...still referencing the central model.  I cannot get the model to detach.
Help..
Fri, Aug 27, 2010 at 10:23:42 AM | Detaching from Central Model...I CANT!
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Once a project has been set to workshared it will always be workshared. The solution is to do as you have done but set the save to save as new central file. This will still be a workshared file but it can reside as a seperate central.
Fri, Aug 27, 2010 at 10:26:55 AM | Detaching from Central Model...I CANT!
gregroberson
gregroberson Avatar
It must be fate...I am working on a Razorback building.  Thanks for the reply
Detaching file from central and working individually
Mon, Jun 4, 2012 at 12:08:49 PM
Central Model rolls back to previous version
Thu, Jun 5, 2014 at 7:47:21 AM
can't view file properties - central path
Fri, Aug 21, 2009 at 2:34:53 PM
updating a revit arch model error (REVIT 12)
Fri, Mar 1, 2013 at 4:06:42 PM
Converting Central Model to Basic Model
Wed, Jul 2, 2014 at 11:48:21 AM
Page generation time: 0.6303
