Forums >> Revit Building >> Technical Support >> Massing
Thu, Aug 26, 2010 at 10:54:28 AM | Massing
trandung
Hi all
I created a box mass with dimensions width: mm length 4000mm hight 4000mm and sketch x,y,z at a point . I want convert this mass to wall and it is same with all dimension .
Can help me this one .
Thanks so much
Thu, Aug 26, 2010 at 12:20:19 PM | Massing
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
In-Place Mass or External Conceptual Mass Family?
Thu, Aug 26, 2010 at 9:51:12 PM | Massing
trandung
in conceptual mass family .
This is home model  with twisted wall
A example wall
Edited on: Thu, Aug 26, 2010 at 10:09:33 PM
Edited on: Thu, Aug 26, 2010 at 10:10:48 PM
Thu, Aug 26, 2010 at 10:11:23 PM | Massing
trandung
Thu, Aug 26, 2010 at 10:33:06 PM | Massing
trandung
I understood this one .
Now I like to create style wall ( same picture) with parameter.
 mass should be conceptual or adaptive component.
Thanks
Edited on: Fri, Aug 27, 2010 at 4:19:17 AM
Fri, Aug 27, 2010 at 8:34:46 AM | Massing
trandung
I just created a family twisted wall with paramater .
It can sketch 8 points with x-y .
There are way more compact?!
Fri, Aug 27, 2010 at 10:28:35 AM | Massing
4 Stars: 205 Votes
Hi Trandung
Do you often use that kind of "Walls" in your projects or you only need for that particular project? because what i see here, you can create that with a simple "Solid Blend", i really like the conceptual mass and the new Adaptive components in Revit 2011, it's a very usefull tool, if you want to learn more about that, check this blog from ZACH KRON: http://buildz.blogspot.com/
Cheers
Fri, Aug 27, 2010 at 7:42:03 PM | Massing
trandung
Thanks Typhoon
I used to read the blog. very interesting about the instructions for creating all kinds of mass.My job often makes the individual house design, so I like to create tools to make quick schemes.Is there a way to draw a twisted sort of like a wall common wall in Revit ?
Edited on: Fri, Aug 27, 2010 at 7:42:30 PM
why my massing can't not be a solid?
Fri, Feb 11, 2011 at 8:26:42 PM
Massing
Mon, Jun 22, 2009 at 9:18:46 AM
conceptual massing...undulating roof shape
Thu, Jun 24, 2010 at 3:01:55 PM
Finding Massing Model
Wed, Feb 23, 2011 at 3:54:53 PM
>>>stuck with creating massing form in revit<<< HELP!
Fri, Nov 6, 2009 at 4:07:53 PM
Page generation time: 0.0370
