Forums >> General Discussion >> Revit Project Management >> Hiding Elements In a Callout
Thu, Aug 26, 2010 at 9:34:48 AM | Hiding Elements In a Callout
jackhoward
Okay, my question is if it is possible to hide elements within a Callout from a floor plan, NOT within the callout view.  I want the elements to display up to the callout line, but then hide within the callout box only from the floor plan.
For example, I have a duct that runs into a room, and my callout view is that room, so on the view from which i created the callout, I want the duct to display up to the callout box, but not within it.
I was just wondering if this was possible, and if so, how to do it.
Thu, Aug 26, 2010 at 10:22:14 AM | Hiding Elements In a Callout
Bimman
Bimman Avatar
1 Stars: 2 Votes
you could put a masking region over top of it. when making your region boundry use inviible lines so your region boundry does not show up.
PWD
Thu, Aug 26, 2010 at 10:38:38 AM | Hiding Elements In a Callout
jackhoward
I tried this, but i don't want to hide the walls and lighting, only the duct work, and i cannot find a filter for this to work.
Thanks for the suggestion, I'm just going to keep playing around with it
Thu, Aug 26, 2010 at 10:53:29 AM | Hiding Elements In a Callout
Other than doing some sort of combination plans (one placed over top the other on the sheet) there would be no way to do this.
Still not clear why you would want to.
Thu, Aug 26, 2010 at 10:57:26 AM | Hiding Elements In a Callout
Bimman
Bimman Avatar
1 Stars: 2 Votes
what about using the linework tool and changing the lines to invisble.
PWD
Thu, Aug 26, 2010 at 12:18:49 PM | Hiding Elements In a Callout
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I'm with WW.
What you need is a Plan Region of Graphics Override.
hiding elements
Wed, Dec 11, 2013 at 11:30:32 AM
Un-hiding selected Elements when Category is Hidden In Visibility Graphics
Mon, Oct 24, 2016 at 1:04:57 AM
Missing Detail Elements
Mon, May 1, 2006 at 12:45:52 PM
Locking hidden elements
Mon, Apr 11, 2016 at 7:04:32 AM
Callout tags
Thu, May 1, 2008 at 11:39:20 PM
12
Page generation time: 2.8240
