Forums >> Revit Building >> Technical Support >> Floor Plans need to show Ceiling on them in Revit 2011
Thu, Aug 26, 2010 at 7:49:59 AM | Floor Plans need to show Ceiling on them in Revit 2011
snutz82
I have ceiling plans as well as floor plans.  However my ceiling plans do not show the elevator shafts, stairs, and misc other things on them.  My floor plans show all of this but I can't get the ceiling information to show up on them.  HELP!!!  Is there a way to show all of this information on one sheet without losing some of it?
Thu, Aug 26, 2010 at 10:27:06 AM | Floor Plans need to show Ceiling on them in Revit 2011
Bimman
Bimman Avatar
1 Stars: 2 Votes
typically ceiling plans do not show any info other then the ceiling grids, fixtures, door frames and window frames.  your floor plans are showing that info because of where your cut is located prob around 4 ft or so looking down.  your ceiling plans is pron 7+ ft or so looking up.  trying working with view rangeand see if that fixes your prob.
PWD
Thu, Aug 26, 2010 at 12:25:59 PM | Floor Plans need to show Ceiling on them in Revit 2011
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Did you know you can place one view on top of another on your sheet. May have to play with Wire Frame etc or tranparency settings in VG. Also turn off the floor becasue you don't need to see it anyway.
Thu, Aug 26, 2010 at 12:35:31 PM | Floor Plans need to show Ceiling on them in Revit 2011
snutz82
I've tried to place a view on top of another with no success.  Maybe because I haven't messed with the transparency settings.  I will try that.  Thank you.
Thu, Aug 26, 2010 at 12:40:35 PM | Floor Plans need to show Ceiling on them in Revit 2011
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I use this same techique for roof plans too when I want to show the load bearing walls below.
Revit 2011 - show ceiling-hosted objects on floor plan?
Tue, May 3, 2011 at 5:47:48 PM
To use or not to use . . Floor plan or Ceiling plan . . . for Mech and Lighting
Tue, Sep 13, 2011 at 11:12:09 AM
Room Tags on Ceiling Plans
Fri, Mar 4, 2005 at 9:36:28 AM
Reflected Ceiling Plans not showing in Electrical Plans
Wed, May 4, 2011 at 1:19:05 PM
Can Railings show in Ceiling Plans?
Tue, Jun 23, 2009 at 1:56:36 PM
Page generation time: 1.7299
