Forums >> Revit Building >> Technical Support >> Evenly Distribute Multiple Text REVIT 2011
Tue, Aug 24, 2010 at 6:56:21 PM | Evenly Distribute Multiple Text REVIT 2011
LaryssaTLS
I am trying to find a way to evenly distribute many intances of text along a line.  This is a function I use frequently in Illustrator under the align panel.  Is this possible in REVIT 2011?
thanks!
Tue, Aug 24, 2010 at 11:24:12 PM | Evenly Distribute Multiple Text REVIT 2011
lab21
Only way to do this would be array or copy the text a consitant dimension.
Unfortunatly you can't align text to other elements, Text can only auto align with other text when dragged, but this won't result in 'even spacing'.
 HTH
Wed, Aug 25, 2010 at 11:19:12 AM | Evenly Distribute Multiple Text REVIT 2011
LaryssaTLS
okay...thanks!  My work-around is to array a line that will then serve as guide lines.
Distribute option problem - Sofistik reinforcement detailing
Fri, Jun 22, 2018 at 5:32:31 AM
Text in multiple columns
Wed, Mar 12, 2008 at 3:39:26 PM
Text Editing (Justification)
Tue, Jun 19, 2007 at 5:47:06 PM
adding text to multiple views simultaneously
Wed, Feb 24, 2010 at 7:30:46 PM
Revit 2011 Multiple Interior Elevation References
Wed, Oct 26, 2011 at 9:01:48 AM
Page generation time: 2.2573
