Forums >> Revit Building >> Technical Support >> Toposurface edge
Thu, Oct 13, 2005 at 7:47:12 PM | Toposurface edge
itchyitchy
Is there a way to view a toposurface in a plan view without its automaticlly generated edge, either turn it off or mask over it? Have tried using the invisible line tool, but alas its not a line! see attached jpg. thanks (pic has been photoshoped to show desired outcome on right) Post edited on 2005-10-13 19:48:11
Thu, Oct 13, 2005 at 8:18:09 PM | RE: Toposurface edge
eldados
eldados Avatar
4.5 Stars: 8 Votes
I'm not aware of any way to remove the site edge, you will need to mask over... but then again I might be wrong Winking
Integrator
KarelCAD
Fri, Oct 14, 2005 at 4:54:00 AM | RE: Toposurface edge
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Nope... Eldad is correct, there is no way to turn off the toposurface edge. Sad
Fri, Oct 14, 2005 at 6:25:10 PM | RE: Toposurface edge
itchyitchy
i have found a way to do it, you just need to set the line colour of toposurface (not primary or secondary contours but the toposurface itself) to white. this seems to take care of it. see attached pic.
Sun, Oct 16, 2005 at 6:04:25 PM | RE: Toposurface edge
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hmm, suppose that would do it... Good idea. (why didn't i think of that....? Brain musn't have been switched on)
Sun, Oct 16, 2005 at 6:24:28 PM | RE: Toposurface edge
JMc
NIce idea!....a simple solution could be used for many things!....that's an example of how Revit with good lateral thinking can achieve heaps! Post edited on 2005-10-16 18:28:12
draping street edge onto toposurface
Mon, Mar 16, 2009 at 4:48:03 PM
How do you put dimensions on a toposurface?
Wed, May 23, 2007 at 10:42:52 AM
property lines hidden by topography
Tue, Sep 26, 2006 at 5:03:59 PM
Pad problem
Thu, Oct 7, 2004 at 12:47:48 AM
Flat Toposurface
Thu, Aug 3, 2017 at 8:58:49 AM
Page generation time: 0.4598
