Forums >> Revit Building >> Technical Support >> RCP and RFP
Tue, Aug 24, 2010 at 1:01:44 PM | RCP and RFP
nwmanj
In a sheet how do I show both the Reflected Ceiling Plan and the Refelcted Floor Plan in the same view? In order for a Fire Suppression design and Fire Alarm Layout. We need to show both RCP and RFP on the same sheet. We are doing this in Revit MEP 2011.
Tue, Aug 24, 2010 at 1:20:59 PM | RCP and RFP
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Create the RCP then 'underlay' the regular floor plan? The underlay field is a 'property' of the view.
Tue, Aug 24, 2010 at 2:33:33 PM | RCP and RFP
nwmanj
It helps but we have an issue with the view range. It does not show everything from the RFP, missing doors and Elevators.
We've adjusted the view range and were able to get the stairs but still missing doors and elevators as marked in attached file.
Tue, Aug 24, 2010 at 2:43:28 PM | RCP and RFP
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Maybe use a 'Plan Region' in those locations.
A 'plan region' allows you to created nested view ranges within the plan. Very handi for those hard to reach places.
Wed, Aug 25, 2010 at 8:12:17 AM | RCP and RFP
HDDWG2003
HDDWG2003 Avatar
3.5 Stars: 11 Votes
DID U CHECK THE VISIBILITY GRAPHICS TO SEE IF THEY ARE TURNED ON?
RFP problem can't find solution please help
Wed, Apr 8, 2009 at 5:05:13 PM
2D light family shows too big on RCP legend
Wed, Jul 3, 2013 at 11:35:44 AM
Sconce in RCP
Fri, Jun 17, 2011 at 8:16:36 AM
dropping in light fixtures and ceiling fans into RCP's
Mon, Aug 11, 2008 at 9:19:45 AM
Rooms in RCP
Tue, Mar 23, 2010 at 9:47:54 PM
Page generation time: 0.2977
