Forums >> General Discussion >> Revit Project Management >> Printing To PDF
Tue, Aug 24, 2010 at 8:24:26 AM | Printing To PDF
bahardman
I am using Revit Architect 2011 and when I print to PDF, all of my text move to the right, what causes this and how do I correct this?
bahardman
Tue, Aug 24, 2010 at 8:31:15 AM | Printing To PDF
This is not a Revit problem - it is your PDF writer.  You need to load the latest driver for that or find another PDF writer like CutePDF.
Tue, Aug 24, 2010 at 8:43:31 AM | Printing To PDF
jterrell
3 Stars: 5 Votes
I use pdfcreator and have no problems. Plus its free.
Tue, Aug 24, 2010 at 9:48:53 AM | Printing To PDF
bahardman
Thanks guys, I will give those other PDF programs a try.
Tue, Aug 24, 2010 at 10:41:38 AM | Printing To PDF
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Outside Acrobat writer I use Cutepdf as well which is also free and works ok but not so good on batch plotting?, only single plots. I will have to try out pdfcreator myself.
Tue, Aug 24, 2010 at 10:47:06 AM | Printing To PDF
We use cute for combined PDF's but yes, for batch plotting, you have to furnish a name for each individual PDF in the order they are created.
Tue, Aug 24, 2010 at 11:37:34 AM | Printing To PDF
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Yes, combersome but free none the less.
Too bad Autodesk could not strike a deal with Adobe and build the PDF driver right in.
Tue, Aug 24, 2010 at 12:29:57 PM | Printing To PDF
carrucha75
carrucha75 Avatar
4 Stars: 24 Votes
i use adobe work fine for me
Not Sure What Revit Can Do?... Find it OUT!!!
Imagination is more important than knowledge...” -Albert Einstein
Tue, Aug 24, 2010 at 12:45:56 PM | Printing To PDF
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Adobe Acrobat Writer? What that cost you ?
Tue, Aug 24, 2010 at 2:57:32 PM | Printing To PDF
jterrell
3 Stars: 5 Votes
Pdfcreator will batch print (auto save) without having to enter the file names, and will combine the drawings to a single pdf easily. that's the only reason I prefer it to others.
Thu, Aug 22, 2013 at 2:42:06 PM | Printing To PDF
helli1
I'm going to jump in...
I'm using Revit LT 2013.  I've been using CutePDF forever with few complaints.  But recently I started preparing light renderings in Revit for some of my clients.  I've been trying to place a perspective rendering (shade/shadow) on a page with a floor plan...or four rendered elevations on a sheet.  Nothing fancy...just to give my clients a little extra.
I usually print everything to PDF and then issue those documents to outside printers and/or print those documents off on my own printer.  It's always worked fine.  But...with the incorporation of renderings into PDF I'm having problems.  Stuff is sporatically being left out....large parts of my drawings.
I grabbed a copy of PDFCreator...same problem.
So...my quesion is this:
"Is this a Revit, Adobe or software thing....or is this a hardware thing? (i.e. RAM, Video Card, Processor, etc.)"  I'm just looking for a little advice.  Thanks.
Tue, Nov 12, 2013 at 3:26:06 AM | Printing To PDF
Nana111
Hi there
Actually ,i am not the user of Revit Architect before.I usually print the pdf files using this code:
using RasterEdge.Imaging.Basic;using RasterEdge.Imaging.Basic.Core;using RasterEdge.Imaging.Basic.Codec;using RasterEdge.Imaging.PDF;RasterEdgeImaging PDF = new RasterEdgeImaging();public void Pdf Processor Print();{PDFInputFile = (@"C:/1.pdf");Printer = (@"C:/HP Color LaserJet 5550 PCL 6");};PDF. PdfProcessorPrint(@"C:/1.pdf", @"C:/HP Color LaserJet 5550 PCL 6");Maybe you can have a try.Hope to help you.
Tue, Nov 12, 2013 at 11:34:28 PM | Printing To PDF
#13
mansell5
3.5 Stars: 4 Votes
if the issue persists with different programs, id look toward maybe
turn off hardware acceleration if its on.
how many dpi are the images being printed to ? maybe try printing to say 150 or 300dpi
if no good maybe ram.
how old is the 'puter? and how much ram etc are you running.
cheers
geoff
Black lines printing grayscale in PDF
Fri, Oct 10, 2014 at 4:46:46 PM
Printing Shadows in .pdf file - Revit 7.0
Wed, Dec 22, 2004 at 9:16:23 AM
Printing Shaded Elevations to PDF
Wed, Oct 19, 2011 at 11:23:07 PM
PDF printing problems
Tue, Dec 3, 2013 at 7:16:18 AM
Printing with Shadows on and PDF
Wed, Jun 3, 2009 at 1:54:17 PM
Page generation time: 0.5236
