17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Room Tags in Linked File
1 Posts No Rating |
I am a lab consultant who uses Revit Architecture (currently using Revit Architecture 2011). As a consultant, we link the architectural model into our own and we typically turn off the architectural room tags and insert our own room names so that we can manipulate the tags (they usually get in the way of our furniture). This always creates "duplicate tag" errors in Revit, that we have to ignore because we don't know how else to get around the issue. It's also a pain because each time we receive a new model from the architect, we have to manually go through and check to make sure that none of the room names or numbers changed. Apparently, you can't Copy/Monitor Room tags. I realize that there is a way to do this using Revit MEP and inserting Spaces, but I guess Autodesk doesn't figure that consultants would be using the same version of Revit as the architect so they haven't added this feature to Architecture. Any suggestions?
How to make room tags in a linked file visable? |
Thu, Jul 30, 2015 at 1:12:22 AM
Linked file Room Tags |
Wed, Apr 17, 2013 at 1:08:27 PM
2011 - Room Tags from a linked file |
Thu, Aug 19, 2010 at 4:10:54 PM
Room Tags not visible in a linked file - Revit 2014 |
Tue, Apr 4, 2017 at 5:54:04 PM
Workset Visibility Issues In Linked File |
Wed, May 7, 2008 at 2:19:36 PM
