Forums >> Revit Building >> Technical Support >> 'Ungroup' causing fatal error in Revit Architecture 2011
Mon, Aug 23, 2010 at 4:08:03 PM | 'Ungroup' causing fatal error in Revit Architecture 2011
allisonkapler
I am drawing a residential project where several of the units are duplicated, I grouped them in order to copy the entire unit and now when I try to 'ungroup' them I get a fatal error everytime. Any suggestions?
Tue, Aug 24, 2010 at 4:02:00 AM | 'Ungroup' causing fatal error in Revit Architecture 2011
4 Stars: 205 Votes
Did you install the Web Update 1 build (20100614 2115) to 2011? Here: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=14973244
check the "Update Enhancement List" first, maybe this can solve the problem
Tue, Aug 24, 2010 at 10:36:19 AM | 'Ungroup' causing fatal error in Revit Architecture 2011
allisonkapler
Downloaded the update this mornings and still having crashes, That time I tried to edit the roof attached the group, in order to modify and un join certain elements to the roof it wanted to ungroup, and again crash.
Tue, Aug 24, 2010 at 10:55:31 AM | 'Ungroup' causing fatal error in Revit Architecture 2011
allisonkapler
Could it have something to do with my video card? Ive got a Radeon HD 5700 Series, and everytime I open revit it says some features may not be fully supported by the video card and driver on this computer : unknown video card ...
Tue, Aug 24, 2010 at 12:30:35 PM | 'Ungroup' causing fatal error in Revit Architecture 2011
4 Stars: 205 Votes
hummm, don't think so, i think it's "memory issue", specs. of your machine? Ram? O.S. (32/64 bits)?, processor?
Tue, Aug 24, 2010 at 12:51:18 PM | 'Ungroup' causing fatal error in Revit Architecture 2011
I don't see anybody else having this issue here or on AUGI.
Tue, Aug 24, 2010 at 1:22:42 PM | 'Ungroup' causing fatal error in Revit Architecture 2011
allisonkapler
Im not too computer suavvy, so hopefully this is what you were asking for...
Intel(R) Core (TM) i5 CPU 750 @ 2.67GHz
8 GB RAM
64 bit operating system.
Tue, Aug 24, 2010 at 1:26:50 PM | 'Ungroup' causing fatal error in Revit Architecture 2011
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Was the content of the project file migrated from an earlier version of REVIT ?
Tue, Aug 24, 2010 at 1:28:33 PM | 'Ungroup' causing fatal error in Revit Architecture 2011
4 Stars: 205 Votes
Well, it's not "memory issue" with 8GB of ram in a 64 bit O.S., nice machine btw.
I also do not WW, this is the first time we have this kind of issue here, did you report this to Autodesk?
Tue, Aug 24, 2010 at 1:33:08 PM | 'Ungroup' causing fatal error in Revit Architecture 2011
allisonkapler
Thanks someone in the office built it, I haven't reported the video card message but this morning when the fatal error caused it to close was the first time it prompted me to report to autodesk and they havent replied yet. Very odd.
Tue, Aug 24, 2010 at 1:34:00 PM | 'Ungroup' causing fatal error in Revit Architecture 2011
#11
allisonkapler
The file was completely created in 2011 but has some imported cad files in it.
Tue, Aug 24, 2010 at 1:44:16 PM | 'Ungroup' causing fatal error in Revit Architecture 2011
#12
4 Stars: 205 Votes
Did you try to "Audit" that file? Also, create a backup file, then open that backup and delete/detach those CAD files, then "Purge", save and try it again...
Tue, Aug 24, 2010 at 2:01:04 PM | 'Ungroup' causing fatal error in Revit Architecture 2011
#13
Are these groups mirrored?  Some families in groups do not mirror well so groups are best defined as left and right.
Tue, Aug 24, 2010 at 2:09:34 PM | 'Ungroup' causing fatal error in Revit Architecture 2011
#14
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
There's a good tip.
Tue, Aug 24, 2010 at 3:31:35 PM | 'Ungroup' causing fatal error in Revit Architecture 2011
#15
allisonkapler
yes some were mirrored! what wouldve been a better way to do that?
fatal error
Wed, Aug 30, 2006 at 1:15:22 PM
Fatal error on a shared job Revit 2015
Tue, Mar 15, 2016 at 1:06:32 AM
Revit Fatal Error
Tue, Jan 12, 2010 at 10:35:50 AM
I Can't use RPC content in Revit Architecture 2011
Fri, Jun 4, 2010 at 9:46:20 AM
Fatal error when in any type of sketch mode
Wed, May 16, 2018 at 11:28:43 AM
Page generation time: 2.4585
