20 Users Online (18 Members):
Forums >> Revit Systems >> Technical Support >> Linking 3D Dwg files from AutoCAD Architecture to Revit MEP
2 Posts No Rating |
I have been struggling with loading in 3d Architectual Dwg into Revit MEP. I link the files, bring them into Revit and when I attempt to take a section view of the model that I have linked.. It just shows the elevation of the building. It wont show interior walls.. Anybody have any ideas?
It sounds like your section isn't cutting through the building. When you draw your section, are you placing it inside the building? what about the extents of the section (green dashed line) is that inside the building as well? Honestly I have never linked a 3d cad drawing in Revit, so there may be something else going on (object enabler?) but if your section is showing an elevation, it sure sounds like it is outside of the building and not cutting through it.
Gary |
2 Posts No Rating |
I have since laid in the floorplans and traced the wall layout with Revit. I still have a Mechanical System that was designed with Auto Duct and I have inserted it into the model. My sections now cut through the building since I reconstructed the building in Revit. But.... of course it doesnt cut through the mechnical system I inserted. I can do a layer query and hide certain elements that shouldn't be shown in the particular section view. Is there a way I dont have to do this? and Revit MEP will recognize that I am cutting through the system.. otherwise it shows all the mechanical components in line with the section view both front and back of the section line. -- Andy
Perhaps the view visibility is the culprit. Do the 3d elements represent as a Mass, if so they are usually turned off by default. checkVP, VG and see if Mass is checked. hth
Edited on: Thu, Aug 26, 2010 at 9:20:59 AM
Gary |
I don't do MEP but in architecture, some family categories do not cut.
Problems linking DWG CAD files into Revit |
Wed, May 14, 2014 at 10:33:52 AM
Linking Revit Architecture files |
Sun, May 12, 2013 at 11:05:15 AM
Linking Revit MEP, Structural Models into Revit Architecture |
Mon, Apr 23, 2012 at 4:00:03 PM
Linked CAD files are not turning off |
Tue, Nov 29, 2016 at 3:31:28 PM
14
Revit MEP or AutoCad MEP |
Fri, Oct 14, 2011 at 8:21:49 AM
