19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Help with dwf visible parameters
I have created some custom families that are not displaying the custon shared parameters i gave them in the revit model in the dwf i exported. Is there any way to make the parameters display in the object properties box in the dwf when the family is slected in the dwf? will revit not export all parameters in the family to be queryable to the dwf? is there certain categories that will not export all parameters to a dwg like generic models or is there no known issues with that? thanks for all of your time! jaysyn
Were the parameters set up as shared? That is what they have to be.
Yes they are shared parameters within the custom families. The category is "Generic Model" and I checked the shared option in the category and parameters portion with in the family editor. I created a parameter named "employee name" which is a shared parameter but when I select the family in the dwf that parameter does not show at all.
DWF Linking |
Thu, Aug 23, 2007 at 12:55:32 PM
how to make AREA BOUNDARY LINE visible when export to DWF |
Fri, Mar 28, 2014 at 3:04:22 AM
Revit views to DWF format to print |
Fri, Mar 19, 2010 at 12:21:41 PM
help! dwf for 2d plans |
Sun, Feb 26, 2006 at 8:15:57 PM
Inconsistent data in DWF exports |
Fri, Nov 20, 2009 at 7:13:48 AM
