Forums >> Revit Building >> Technical Support >> Fireplace
Thu, Oct 13, 2005 at 1:29:03 PM | Fireplace
mage
I'm a really new Revit user and I downloaded a fireplace from the Revit 8.1 Library, under Misc. Architectural, the Masonry Chimney-Wall. Try as I might, I cannot make the chimney shorter without running into problems. Can anyone give me insight into how to do this, please? Thanks in advance for any help. I can be emailed at allan@mccomb.com. Allan McComb
Thu, Oct 13, 2005 at 8:23:35 PM | RE: Fireplace
eldados
eldados Avatar
4.5 Stars: 8 Votes
have you tried to open the family and edit the fire place? where do you try to shorten the chimney?
Integrator
KarelCAD
Fri, Oct 14, 2005 at 12:20:20 AM | RE: Fireplace
mage
Yes, I've tried that. And I've tried in different views. I've also tried properties and even duplicated it to try to change it. Nothing seems to work.
Fri, Oct 14, 2005 at 3:47:58 AM | RE: Fireplace
fazerneil
4 Stars: 5 Votes
Having just tested it the family needs some work The brickwork chimney breast is a family type parameter so you can change the height without any problem but then the concrete capping does not follow suit. The base of the capping is locked in place already so all you have to do within the family is to open up an elevation and add dimension from base of capping to top of capping and lock this dimension. Make sure you select capping and not reference lines. Now go into family types and change chimney height to something different and the capping will follow. Just remember, if you want chimneys of differing hts within a single project. Change the family parameters to instance parameters instead of type parameters within the family types box. Load into project and away you go.
Fri, Oct 14, 2005 at 8:33:06 AM | RE: Fireplace
mage
Thanks. That's exactly what happened. Thank you for taking the time to check. I'll try what you suggested.
Sat, Oct 15, 2005 at 1:20:23 PM | RE: Fireplace
mage
Well, tried it (I think), and no luck. Here's what I did: highlighted chimney, clicked on edit family, opened chimney for editing, went to back side elevation, added cap dim (made sure I got cap and not reference line) and locked it. Then went back to the house elevation, highlighted chimney once again, clicked on edit box to arrive at the type dialogue box, changed height to 18' (instead of 24'Winking, and, once again, the cap got really big. Am I doing something wrong? Thought I understood and followed your excellent directions.
Mon, Oct 17, 2005 at 3:28:32 AM | RE: Fireplace
fazerneil
4 Stars: 5 Votes
Mage, did you save changes to family and then reload the chimney breast back into your project accepting changes to existing family loaded in ? Sorry to state the obvious but you did not mention these in your last message ?
fireplace help
Mon, Dec 12, 2011 at 4:11:29 AM
fireplace
Thu, Mar 17, 2011 at 8:34:26 AM
guys please help me i need a fireplace
Fri, Mar 22, 2019 at 2:12:57 PM
Fireplace doesn't export out into STL file
Sat, Jan 24, 2015 at 9:24:41 AM
fireplace
Mon, Mar 7, 2005 at 4:52:35 PM
Page generation time: 0.0104
