15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> R2009 to R2011 conversion
I just got done learning revit 2009 last year. Now we have Revit 2011. Is there a way to set up the screen interface of 2011 the same as 2009?
Not really. You need to learn the ribbon since this is the only way Revit is fully accessible. After awhile, I think you will find that you like it better.
you will be better off in the long run working with the new ribbon.
Agree 100% The ribbon interface provides a much better workflow than that of the classic UI. Between the all the context sensative aspects of the ribbon and short cut keys, it is much more profecient.
host sweep not working in R2009 when roof fascia option used on ridge and hip li |
Sat, Sep 26, 2009 at 10:07:00 AM
Sky properties in r2009 |
Mon, Jan 12, 2009 at 11:23:25 PM
How to set custom unit conversion value |
Thu, Jul 17, 2014 at 5:27:32 AM
parameter to dontrol 3-d darkness |
Mon, May 24, 2010 at 10:51:47 AM
Why can't you upgrade your file to 2009? - I DID! |
Mon, Aug 25, 2008 at 7:05:10 AM
