Forums >> Revit Building >> Technical Support >> 2011 - Room Tags from a linked file
Thu, Aug 19, 2010 at 2:14:13 PM | 2011 - Room Tags from a linked file
amandaholly
I read that you are able to tag elements in 2011 that are within linked files.  I am attempting to do this with rooms.  So far the only way I have found to actually do this is to go to Visiblity Graphics --> Revit Links --> select display settings of the linked file --> set to custom --> select a linked view.
this allows you to select a vew in the linked file that has the annotations such as room tags so they will at least show up.  The issue I have is this - what if I want to move a room tag around inside the boundaries?  Is there a way to place a room tag in the 'live' revit model the denotes the room for the linked file?
Thanks!
Mandy
Thu, Aug 19, 2010 at 3:03:26 PM | 2011 - Room Tags from a linked file
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Unfortunately, Rooms, Spaces and Areas cannot be tagged across a linked file.
Maybe in the next release?
Depending on the project, we may just use a linked view just as you described but if more control is desired, ultimately you need that element in your model. The ulternative would be to use a generic annotation, but that is kind of anti-BIM.
I saw a model from Autodesk that had rooms placed in both the C&S file and the INT model to handle just this issue.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Thu, Aug 19, 2010 at 3:58:54 PM | 2011 - Room Tags from a linked file
amandaholly
I thought so but I was hoping I was wrong.  Dumb question but what is the C&S file and the INT model?
Thanks!
Thu, Aug 19, 2010 at 4:10:54 PM | 2011 - Room Tags from a linked file
brettgoodchild
4 Stars: 17 Votes
That's not a dumb question at all Smile
On larger model files we break the architectural discipline into seperate model files usually consisting of a Core and Shell (C&S) and an Interiors (INT) model then link them together to continue production.
                             ~ Abraham Lincoln
How to make room tags in a linked file visable?
Thu, Jul 30, 2015 at 1:12:22 AM
Linked file Room Tags
Wed, Apr 17, 2013 at 1:08:27 PM
Room Tags not visible in a linked file - Revit 2014
Tue, Apr 4, 2017 at 5:54:04 PM
Room Tags in Linked File
Mon, Aug 23, 2010 at 6:48:45 PM
Workset Visibility Issues In Linked File
Wed, May 7, 2008 at 2:19:36 PM
Page generation time: 1.2764
