11 Users Online (9 Members):
Forums >> General Discussion >> Revit Project Management >> Missing Element Properties Ribbon
16 Posts No Rating |
As I am starting to work in 2010, for example, I start with selecting a wall...the element properties ribbon should show up at the top of the screen but it does not. Neither does it happen for anything else (hatching, doors, etc). How do I change this setting? thanks
This is a new feature in 2011. You now get a pallete like you do in ACAD. Select an element and then look for the properties button in the upper left corner. By default the properties dialog box would display right above the project browser. The properties dialog box would always be open or you have the option to right click, select propeerties the way that you used to. Hopefully this will answer your question.
Oh Blaine, You know how to impress me dont chu
Revit 2013 extensions disappeared from the ribbon |
Sun, Apr 7, 2013 at 8:44:42 PM
revit architecture 2012 missing ribbon tabs |
Tue, Sep 17, 2019 at 8:13:49 AM
Revit 2010 Extruding Multiple Surfaces all at once? |
Sun, Feb 14, 2010 at 3:03:26 AM
Missing Orientation option (Project North/True North) in Properties Palette |
Fri, Jan 29, 2016 at 11:23:52 AM
Elements Missing in Render Image |
Mon, Sep 27, 2010 at 7:21:17 AM
