Forums >> Revit Structure >> Technical Support >> Rotating plans
Thu, Aug 19, 2010 at 11:47:29 AM | Rotating plans
davidlowery
OK, three weeks into the project the Architect decides to rotate all the plans so North is up.  Previously they had North as left.  So I basically need to rotate everything (7 or 8 plans on several sheets) clockwise 90 degrees.  Any hints?
Thu, Aug 19, 2010 at 11:52:56 AM | Rotating plans
Quincer
I tried this in one of my projects in 2010.  Under the view properties there is a Orientation parameter.  Change the value to True North.  Give that a try.
Thu, Aug 19, 2010 at 4:20:49 PM | Rotating plans
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
I guess the answer here depends on your project needs.
If you actually are changing the buildings orientation to True North, then you need to read the help file on "Project North" & "True North" and learn how to set and control them.
If you are simply rotating a view's orientation on a sheet, then read the help file on "Rotating Views".
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Rotating details on sheets without rotating their callouts in plan
Wed, Dec 10, 2008 at 5:28:37 PM
LINK ROTATING INCORRECTLY
Tue, Mar 18, 2008 at 11:12:48 AM
Rotating views to project north
Mon, May 28, 2007 at 3:46:10 PM
Rotating Symbol geometry without rotating leabel
Wed, May 6, 2009 at 8:33:58 AM
Rotating mullions
Thu, Jul 24, 2008 at 4:27:53 PM
Page generation time: 1.4506
