Forums >> Revit Structure >> Technical Support >> Beam skews at an angle
Thu, Aug 19, 2010 at 10:41:19 AM | Beam skews at an angle
Kelly105
Hi. Newbie here.  Here's my problem:
 I moved my slab edge out a couple of feet and I'm trying to drag the beam end to meet the edge of slab.  Instead of going straight out and becoming flush with the slab edge, the beam skews at an angle.  Is there anything I can do to fix this?
Thu, Aug 19, 2010 at 11:03:15 AM | Beam skews at an angle
pdoug
3 Stars: 2 Votes
Welcome!
 If I am uunderstanding you correctly, one thing you can do is place an angular dimension from the beam to the slab edge.  Select the beam, and edit the angle.
One thought: Try out the align tool under the Modify tab - this would have aligned the beam with the slab edge or vice versa very nicely!
Thu, Aug 19, 2010 at 11:46:33 AM | Beam skews at an angle
Kelly105
I tried the "align" command and it worked perfectly!  Thanks!
Steel Beam - Angle
Thu, Feb 1, 2018 at 4:02:25 AM
Angled Beam Issue
Mon, Aug 26, 2013 at 6:09:39 AM
Drawing a Chord Angle
Mon, May 12, 2008 at 1:00:41 PM
parametric beam
Sun, Jul 23, 2006 at 6:46:24 PM
Spot Lighting Beam Spread
Sun, Nov 9, 2008 at 9:20:16 AM
Page generation time: 0.3375
