Forums >> Revit Building >> Technical Support >> AUTOCAD 2006 - OBJECTS DISAPPEAR WHEN PLOTTING
Thu, Oct 13, 2005 at 10:01:34 AM | AUTOCAD 2006 - OBJECTS DISAPPEAR WHEN PLOTTING
wkarabinos
THIS ISNT ABOUT REVIT BUT I WAS HOPING SOMEONE MIGHT BE ABLE TO HELP. THE OTHER DAY I WAS WORKING ON A JOB THAT I WORK ON JUST ABOUT EVERY DAY. NOW I WAS MAKING PDF FILES TO SEND TO A CLIENT FOR A MEETING, AT FIRST I MADE A DWF FILE WITH AUTODESKS DWF WRITER, THEN AFTER THAT I USED ACROBAT DISTILLER. NOW EVER SINCE THAT DAY I MADE THE PDF FILES ALL OF THE CHANGES THAT I MADE TO THE FILES ON THAT DAY ARE VISIBLE IN THE MODEL BUT WHEN I GO TO PLOT OR DO A PLOT PREVIEW CERTAINS ITEMS ARE NOT VISIBLE. IVE TRIED EVERYTHING THAT I CAN THINK OF TO FIX THE PROBLEM AND NOTHINGS WORKING FOR ME. ITS NOT ANY KIND OF LAYER ISSUES BECAUSE OBJECTS THAT ARE ON THE SAME LAYER ARE VISIBLE IN SOME SPOTS AND NOT IN OTHERS. I HAVE TRIED ERASING AND REDRAWING AND STILL NOTHING. I TRIED CREATING A NEW FILE AND INSERTING THE XREFS AGAIN AND STILL NOTHING.
Thu, Oct 13, 2005 at 4:25:02 PM | RE: AUTOCAD 2006 - OBJECTS DISAPPEAR WHEN PLOTTING
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Sounds very strange. Would need to have a look at the file to fully understand what's going on. Does printing to raster as opposed vector force them to print?
Thu, Oct 13, 2005 at 4:38:12 PM | RE: AUTOCAD 2006 - OBJECTS DISAPPEAR WHEN PLOTTING
wkarabinos
IT HAS SOMETHING TO DO WITH THE XREF. IF I W-BLOCK THE XREFED FILE TO ANOTHER LOCATION THEN REINSERT THE NEW XREF INTO THE DRAWING IT SEEMS TO PRINT FINE. FOR NOW ATLEAST, I READ SOME THINGS ON DIFFERANT WEBSITES ABOUT THE DISAPPERING OR MISSING LINES BUT I HAVENT FOUND A PERMANENT FIX FOR THE PROBLEM
Mass objects disappear in PDF
Wed, Nov 29, 2006 at 9:17:49 AM
Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects
Fri, Oct 12, 2012 at 7:31:58 AM
Plotting Revit Projects in AutoCAD 101
Fri, Mar 26, 2010 at 7:12:17 AM
Imported AutoCAD 2006 title block line thickness
Thu, Sep 7, 2006 at 3:27:44 PM
Plotting
Mon, Oct 20, 2008 at 10:23:02 AM
Page generation time: 0.2632
