27 Users Online (25 Members):
Forums >> General Discussion >> Revit Project Management >> Indicating a Furr Down
Trying to find the best practice to indicate a furr down. Old School in CAD I would have a section cut indicated at the furr down on my reflected ceiling plan. Any good ideas out there? Thanks
Whad do you mean "section cut"? I assume your ceiling plan is cut around your cabinets.
well you know you work in AutoCAD for 12yrs it's hard to get way from things. But what I'm talking about is, I have a ceiling at 9'-0" Then I have a furr down and the other side the ceiling moves up to 11'-0". In cad on the ceiling plan I used to place a tag to call out that furr down detail. I just have not found a good way to call that out. Any suggestions would be great. Thanks,
Why could'nt this be a "ceiling" called "Furr Down" .... Then when you tag this ceiling, it would say furr down and have an elevation.... Or just use a key note?
I have made an 'architectural beam' family that is really a horizontal column family. It joins to walls and shows a dashed line at the floor level. If I don't use that family, I just draw walls with an offset from the referenced floor.
Creating furr downs above cabinets... |
Fri, Jul 13, 2012 at 8:36:37 AM
Furr down and ceiling joins |
Wed, Mar 16, 2011 at 7:47:52 AM
Trouble getting furr down walls @ ceiling to actually be room bounding.......... |
Tue, Jan 26, 2010 at 11:58:10 AM
spot elevations indicating schedules symbols |
Fri, Apr 23, 2010 at 4:46:16 PM
Showing voids in plan |
Mon, Nov 12, 2007 at 3:13:46 PM
