18 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> exporting to dwg
14 Posts No Rating |
1. The export from RVT to DWG format gives a result a number of drawings which I do not understand why?. Therefore I have 85 dwg files( for example) while I only A1 to A15 ( 15 sheets) . Is it possible to make it one dwg for each sheet created? thanks sudanhafif
1. The export from RVT to DWG format gives a result a number of drawings which I do not understand why?. Therefore I have 85 dwg files( for example) while I only A1 to A15 ( 15 sheets) . Is it possible to make it one dwg for each sheet created? maybe you have too many files export to DWG so it gives you more dwg files exported...try to use ungroup files... " /> " /> " />
49 Posts No Rating |
Sudanhafif, Did you uncheck the 'Xref views on sheets' while exporting to dwg?
Exporting views for DWG |
Thu, Oct 24, 2019 at 5:52:23 PM
Exporting to DWG |
Fri, Oct 6, 2006 at 9:08:49 AM
Exporting views with DWG bocks to dwg. |
Sun, May 21, 2006 at 8:36:59 PM
Compound Ceiling Grid Not Exporting to DWG |
Mon, Jul 8, 2013 at 9:53:46 AM
Dimension problem when exporting Revit to DWG |
Tue, Apr 12, 2011 at 11:15:43 AM
