Forums >> Revit Building >> Technical Support >> Show door swings in RCP?
Tue, Aug 17, 2010 at 1:36:13 PM | Show door swings in RCP?
Snodaisy
Hey guys! Just the door swing needs to be seen in the RCP. Not the cut in the wall. Have untoggled the "Show only if Instance is cut" visiblity selection for the symbolic lines that make up the swing. Still will not show. Have also tried to create lines on a reference plane @ 7'6" (Cut line for RCP). What would you try? or have tried?
looking through the other threads, the answers seem to be showing wall cuts as well (vis-avis lower the cut plane and tailor the visibility selections.) So if there's more out there that you think would be heplful, please let know!
thank yoU!
-S
Door swings in RCP
Thu, Jul 18, 2019 at 5:03:06 PM
creating double door with multiple swings
Fri, Oct 31, 2014 at 1:44:28 PM
Door swings in 3d view
Tue, Dec 1, 2009 at 7:41:35 AM
Door swings not showing in plan view
Mon, May 5, 2008 at 7:27:38 PM
Hide door swings which are visible from floor below
Wed, May 6, 2015 at 12:16:03 PM
Page generation time: 3.3868
