13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> "Link" schedule into legend?
Hey guys, I need some help, if you watch the picture that I've attached you can see two parts, the left part which is from the Legend I've made, and the bottom/right part that I've copy pasted in paint. This i copied from my Window-Schedule. What I wonder is, how do i link my window schedule like this into the legend? As I might link a Schedule into a sheet? Kindest regards! EDIT: Another question, is it possible on the window-schedule to not just write what quantity of windows i have, but also how many there is on each floor?
Edited on: Mon, Aug 16, 2010 at 7:03:03 AM
Sorry but there is no way toi link the scedule to the legend automatically. You will have to use a manual callout. Did you look at adding levels to your window scedule then sort and count?
"Sorry but there is no way toi link the scedule to the legend automatically. You will have to use a manual callout. Did you look at adding levels to your window scedule then sort and count?" Aah, silly me. The window on level problem was non existent, but the legend is a bit bad. It seems you can't even make a callout on legends or sheets, just on the different Plans. Any idea if you can solve it in any other way? Maybe if i can acccess the .txt file and import it in some way via it?
Edited on: Mon, Aug 16, 2010 at 7:24:01 AM
VIEWING LEGEND COMPONENTS PROPERLY |
Tue, Apr 14, 2009 at 10:04:02 AM
"Room From" and "Room To" NOT updating in Door Schedule??? |
Wed, Jan 20, 2016 at 1:17:43 PM
Title Block link from Schedule? |
Thu, Sep 13, 2007 at 4:12:00 AM
Legend Drawing # on Sheets |
Wed, Dec 12, 2007 at 8:36:16 AM
Partition Schedules or Legend? |
Thu, Jan 5, 2006 at 7:23:27 PM
