Forums >> Revit Building >> Technical Support >> Text Masking in annotations
Wed, Oct 12, 2005 at 8:21:19 PM | Text Masking in annotations
psymon
psymon Avatar
3.5 Stars: 6 Votes
I am creating new annotation symbols, level heads, door tags etc. I have found that if I create the text last, the text masks the geometry of the surrounding tag box or in the case of level heads, if I put them too close together they obscure eachother. Is there anyway to reduce this mask size or send the text to the back. I can't find a reference to this anywhere. Any help would be appreciated. Also, is there anyway to make the text in annotations all in capitals? Post edited on 2005-10-12 21:15:54
Wed, Oct 12, 2005 at 11:47:24 PM | RE: Text Masking in annotations
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
1. Make the text background transparent as opposed to opaque. You cannot adjust the masking, but you can turn it off. 2. Type it in capitals or use a font that is all capitals... HTH.
Thu, Oct 13, 2005 at 2:57:45 AM | RE: Text Masking in annotations
psymon
psymon Avatar
3.5 Stars: 6 Votes
Thank you. I have found the documntation provided for this program "light" to say the least
Tue, May 10, 2011 at 10:38:55 AM | Text Masking in annotations
ideaguy
ideaguy Avatar
Saying the documentation help is light is a complement, AutoDesk help menus are virtually non-existant, helpless.
If it wasnt for these forums, they woudl be out of businuess. I really miss all the hard copy documentation from Autocad Release 12
Text Box Width Factor Masking Error
Wed, Mar 18, 2015 at 2:33:50 PM
Masking Regions in Symbols not working
Thu, May 7, 2009 at 5:47:00 PM
White Border Masking Around Annotations
Thu, Jul 10, 2014 at 1:34:09 PM
Annotations and text
Mon, Mar 21, 2005 at 6:13:45 AM
Masking Text in callout
Tue, May 10, 2011 at 5:43:29 PM
Page generation time: 1.2193
