19 Users Online (17 Members):
Forums >> Revit Structure >> Technical Support >> Strucutral Columns VS Walls in Call outs
40 Posts No Rating |
I am working in Revit 2011 and my walls are being cut by the structural columns in regular plan views however for my enlarged details i an using callouts of the plans. In the call outs the structural columns are not cutting the walls. Anyone have this problem or know the fix? Thanks,
I have seen some similar issues like this but I can't remember the circumstances. Are you callouts plans or details? Try switching between them.
49 Posts No Rating |
Emmettking, If you callout from plan, please also check if the material of wall and column are same. If they are/should be different , try splitting the wall to be cut for the structural column.
Edited on: Mon, Aug 16, 2010 at 6:20:25 AM
For whatever reason the callouts are detail views instead of plan view types. As long as the callout is made in the floor plan as a "plan" callout everyhting works fine. No idea how someon made them into or made them as detail views. thanks for the help.
Call outs withing call outs |
Sun, May 10, 2009 at 3:35:42 PM
Call outs in Revit |
Wed, Jun 11, 2008 at 8:39:23 AM
Call Outs |
Sat, Feb 27, 2010 at 5:23:33 AM
Elevation call outs missing |
Thu, Apr 3, 2008 at 8:35:13 PM
Changing options on call out views so able to see on all floors |
Thu, Oct 29, 2009 at 6:33:51 AM
