Forums >> Revit Building >> Technical Support >> Setting up a campus project
Fri, Aug 13, 2010 at 6:28:15 AM | Setting up a campus project
archie456
3 Stars: 1 Votes
Hi,
I'm about embark on setting up a campus project (or at least learning how to).
This will be a site revit model, and then another 5 buildings, in separate revit files, linked into the site plan.
Can anyone recommend some tutorials and best practice on setting up a campus project including sharing the co-ordinates.
This would be a great help
Thanks.
Fri, Aug 13, 2010 at 7:10:48 AM | Setting up a campus project
Look in the AUGI EDGE magazine for some good articles on project north and shared coordinates.  Also of course, read your HELP.
Since you will have 5 linked into one, I would have all the building files have their exterior shells on seperate worksets so that in the site file, these would be the only worksets on.
Fri, Aug 13, 2010 at 7:22:18 AM | Setting up a campus project
archie456
3 Stars: 1 Votes
Thanks for that.
Can I ask, in principle, is it just a case of having the site plan in one file, at the correct angle to north and at the correct co-ordinates.
And then for each buiding you would draw it orthagnal to the screen in a separate Revit file at no particular origin (but at the correct height)
Then you would like the building into the site plan, and move / rotate it into place.
Is that correct?
Fri, Aug 13, 2010 at 7:29:43 AM | Setting up a campus project
I think the following is the easist way:
  1. Create your site plan in a file with true north up.  You can roteate the view at any time then to really work on it.
  2. Start a building project and link the site into it origin to orgin.   The site might be at a skew but don't worry about that.
  3. Determine how this building will sit in relation to the site.  Maybe draw a reference base line.
  4. Now you can adjust so that all your views are orthaginal and everything will work with the site.
Fri, Aug 13, 2010 at 7:43:00 AM | Setting up a campus project
archie456
3 Stars: 1 Votes
OK. Thanks for that.
Any particular issue for AUGI Edge?
Fri, Aug 13, 2010 at 7:56:08 AM | Setting up a campus project
Download all of them.  There are useful articles in them.
Campus mapping
Wed, Jul 11, 2007 at 5:15:22 PM
grids in a campus setting
Wed, Feb 25, 2009 at 11:03:41 AM
Modeling a campus
Fri, Oct 27, 2006 at 8:11:45 PM
Linework in linked files
Mon, Mar 12, 2007 at 4:57:03 PM
Large Campus Project
Fri, Sep 17, 2021 at 1:28:34 PM
Page generation time: 1.1143
