Forums >> Revit Building >> Tips & Tricks >> Importing a METRIC CAD survey file generates topo lines at wrong elevation
Wed, Aug 11, 2010 at 6:55:46 PM | Importing a METRIC CAD survey file generates topo lines at wrong elevation
iamian33
iamian33 Avatar
Greetings ...
I am trying to generate a Toposurface using the "Select Import Instance" command.  In METRIC ...
  • My Revit environment is based on the Metric template supplied with Revit 2011. Units are set to millimeters ...
  • the CAD file is in metric units w/ millimeters set as the Units.
When I create the toposurface, the points are not at the correct elevation.  The CAD file has the contour lines at 516 but Revit generates the topo at 516000.
I know that this is a meter vs. millimeter issue so I reset the units (CAD file) to "meters" but I got the exact same result.
  • I've imported the CAD file with the units set to meters and then millimeters
  • If someone can offer help, I'd be truly grateful.
    Ian
    Ian Shafer
    Principal Consultant
    True North S&F Consultants
    Thu, Aug 12, 2010 at 4:28:24 AM | Importing a METRIC CAD survey file generates topo lines at wrong elevation
    4 Stars: 205 Votes
    "I know that this is a meter vs. millimeter issue so I reset the units (CAD file) to "meters" but I got the exact same result. " - And in your Revit project did you cange your units to METERS too?
    Thu, Aug 12, 2010 at 9:40:21 AM | Importing a METRIC CAD survey file generates topo lines at wrong elevation
    iamian33
    iamian33 Avatar
    thanks for your interest.  I did change the Revit file to import in meters ... but the cad file came in 1/1000 scale.I also changed the Revit file environment to meters but then the existing information (walls, level marks) also changed.
    Perhaps I need to import the site into a brand new model then set up the levels and re-add the walls ...?
    Ian Shafer
    imported topo file not elevating correctly
    Fri, Feb 29, 2008 at 12:56:01 PM
    Importing AutoCAD topo 3D lines
    Wed, May 25, 2005 at 3:33:44 AM
    Importing topo surface from CAD in Revit
    Fri, May 1, 2015 at 7:28:19 AM
    Topography Elevation from Project Base and Survey Point is Incorrect
    Thu, Jan 29, 2015 at 10:32:24 PM
    Importing a cad file
    Fri, Apr 27, 2012 at 3:33:21 PM
    Page generation time: 1.8762
