28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> basic vs compound ceiling
59 Posts No Rating |
Has anyone else had issues with basic ceilings when demo'ing lights (or ceiling-hosted elements in general)? Apparently, every time we demo a light on a basic ceiling, it creates a new ceiling entirely. We were experiencing graphic issues, as well as time delays with revit because it had generated 189 ceilings (a ceiling per demo'd light)! Through a painful process of undoing, and changing the ceiling to a compound ceiling we were able to remedy the issue. Moral of the story - DON'T USE BASIC CEILINGS!
----------------------------------- Bradley |
Wow ... you are right - that is really strange! I suggest you report this as a bug. BTW - The purpose of the Basic Ceiling is to have a ceiling for exposed structure areas that will host ceiling objects. It really has no thickness and will not hide what is above it. If you want a ceiling, use a compound ceiling.
Actually, the basic ceiling does hide everything that's above it. I don't see any setting that changes this. If you know of another object type that accompishes this, please let me know.
If that is true, thyen they changed this from earlier releases. I don't have Revit here to check.
non compound wall acting like compound wall |
Mon, Feb 20, 2012 at 2:30:22 PM
Compound Ceiling Grid Not Exporting to DWG |
Mon, Jul 8, 2013 at 9:53:46 AM
How to create a custom compound ceiling? |
Thu, Nov 5, 2009 at 12:53:14 PM
Gypsum ceiling with vertical walls to create soffit? |
Thu, Dec 18, 2008 at 9:34:06 AM
Irregular Ceiling |
Mon, Aug 4, 2008 at 1:45:52 AM
