Forums >> Revit Structure >> Technical Support >> Revit Structure 2011 view question
Wed, Aug 11, 2010 at 11:07:30 AM | Revit Structure 2011 view question
davidlowery
OK, I just modeled in some existing walls and their footings.  Everything was great.  But when I changed the footings from "new construction" to "existing" in the properties, the footings show up as solid lines instead of the hidden lines.  I change them back to "new" and they go to hidden again.
Wed, Aug 11, 2010 at 11:42:03 AM | Revit Structure 2011 view question
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Is there a question in there somewhere?
Wed, Aug 11, 2010 at 12:18:53 PM | Revit Structure 2011 view question
davidlowery
Sorry.  I want the footings to appear as hidden lines on the plan view.  They are, until I change them to the existing phase.  Why do they change from hidden to solid when I change the phase?
Fri, Aug 13, 2010 at 3:58:48 PM | Revit Structure 2011 view question
shaverjeff
This is due to your view's "Phase" and "Phase Filter" settings coupled with the project "Phase Filters" and "Graphic Overrides" settings within the Phasing dialog.
Once you get your settings adjusted as desired in the phasing dialog, confirm that your view phase settings are correct.
Inventor to Revit Structure 2010 or 2011
Fri, Dec 10, 2010 at 5:45:29 AM
Copy/Monitor Walls Creates Too Many Family Types (REVIT Structure 2011)
Fri, Jan 14, 2011 at 1:27:26 PM
Revit Structure 2011 Properties Dialoge box annoyance
Wed, Sep 7, 2011 at 10:02:36 AM
Hello All! Moving Revit Arch Drawing to Revit Structure Problems
Thu, Feb 12, 2009 at 8:18:59 AM
Metalic Structure in Revit Architecture
Fri, Dec 3, 2010 at 1:10:10 PM
Page generation time: 2.7246
