Forums >> Revit Building >> Technical Support >> door family and to/from room selection
Wed, Aug 11, 2010 at 9:10:32 AM | door family and to/from room selection
burke424
I have an overhead door family (I don't know where it originated from) that will not detect the from or to room for the schedule unless I offset it down 2'-6". Any idea what I need to do to the family to fix this?
Wed, Aug 11, 2010 at 10:59:04 AM | door family and to/from room selection
This may be a room issue.  Did you look at where the top of your room is?
Otherwise, we would probably have to look at the family.
Wed, Aug 11, 2010 at 11:02:34 AM | door family and to/from room selection
burke424
the top of the room offset is set at 8'-0. Other doors into the same rooms work. This door family doesn't work in any of the rooms.
Wed, Aug 11, 2010 at 11:19:48 AM | door family and to/from room selection
Well ... it works if your room height is set higher .... as I suggested...
Wed, Aug 11, 2010 at 11:26:50 AM | door family and to/from room selection
burke424
Thanks. Setting it higher did fix it.
My doors were only 10' tall and I had been told as long as the offset was more than half of the door height it would work. Guess that was not quite true.
automating door schedule ( From room # To Room #)
Thu, Jun 20, 2019 at 2:14:07 PM
A better method for family and family element selection. More like ADT pallets
Wed, Jan 26, 2005 at 5:51:18 PM
room names not being picked up in door schedule
Mon, Apr 21, 2008 at 10:26:48 AM
Door room boundary
Thu, May 24, 2012 at 7:24:50 AM
Schedules. How do I avoid having a schedule row for every door, room & window?
Wed, Aug 15, 2012 at 7:24:44 AM
Page generation time: 3.0139
