Forums >> Revit Building >> Technical Support >> Inconsistent units
Tue, Aug 10, 2010 at 11:17:06 PM | Inconsistent units
camncam
I'm trying to set up a parameter for use with an array group in a family. I have created the parameter but when I enter the formula "=Length/50" as in length divided by 50mm, i get an error meesage "Inconsistent units". What does it mean? How do I get around it?
Wed, Aug 11, 2010 at 7:47:05 AM | Inconsistent units
If length is in your formula, then the parameter has to be a length parameter.  ... and obviously, length can not be used in an array number.... You need an integer so your formula has to reslove this.
Wed, Aug 11, 2010 at 8:17:26 AM | Inconsistent units
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Try this (Length/50)*1mm. this will return the value in milimeters.
I don't know what you are trying to accomplish with the array but this formula will solve the "inconsistent units" problem.
WWHub is correct however and the parameter type probably needs to be an integer.
Edited on: Wed, Aug 11, 2010 at 8:18:08 AM
The Bane of Formulas - Inconsistent Units
Wed, Jul 2, 2014 at 4:39:36 PM
Inconsistent units workaround
Wed, Jun 22, 2005 at 7:52:54 AM
Inconsistent Pi
Sun, Mar 1, 2009 at 5:45:25 AM
'Inconsistent units" error in parameter formula; length vs integer
Fri, Dec 13, 2013 at 10:37:04 PM
Schedule Total Costs
Fri, Dec 30, 2005 at 1:34:43 PM
Page generation time: 0.0591
