Forums >> Revit Building >> Technical Support >> Need to make a 1" tall wall
Tue, Aug 10, 2010 at 9:39:24 AM | Need to make a 1" tall wall
jwetmore
It seems that REVIT has a minimum heigh for walls or portions of a stacked wall.  I am creating a tile wainscot that has bands of various types of tiles.  I am setting these bands up as stacked walls.  Some of these bands are only 1" tall.  But REVIT will not allow me to make a portion of a stacked wall less than 1 1/2".  Does anyone have any ideas on how to do this?
 I have already thought about using sweeps for the tile bands.  The problem is that I am doing material quantity takeoffs so that I know exactly how much of each type of tile to order.  The sweeps do not calculate in the quantiy take off and thus will not work.
Tue, Aug 10, 2010 at 11:04:54 AM | Need to make a 1" tall wall
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
build as separate walls perhaps.
Tue, Aug 10, 2010 at 11:23:06 AM | Need to make a 1" tall wall
jwetmore
unfortuneatly that won't work either.  If I take two types of walls and place them on top of each other (insetad of an actual stacked wall) I cannot make those walls as short as 1".
Tue, Aug 10, 2010 at 11:37:49 AM | Need to make a 1" tall wall
Why fight this.... I would just get my wall lengths and apply the math.   Does this really have to be modeled or could it be a type... 20 feet ow x wall that is ......
Tue, Aug 10, 2010 at 12:37:57 PM | Need to make a 1" tall wall
jwetmore
Tue, Aug 10, 2010 at 12:46:47 PM | Need to make a 1" tall wall
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I have made walls 1/16" high in order to make footings go under openings, but not stacked.
Tue, Aug 10, 2010 at 1:03:18 PM | mbsteve
jwetmore
Quoting mbsteve from 2010-08-10 12:46:47
I just tried making a 1/16" high wall and it won't work.  How did you manage to do it?
Tue, Aug 10, 2010 at 1:17:58 PM | Need to make a 1" tall wall
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Think I made full height and then modified the height at openings to get footings to go through.
Tue, Aug 10, 2010 at 1:55:28 PM | Need to make a 1" tall wall
Bfresh
Why not make a compound wall with the tile set to your height and split the face of the tile as many times as you want horizontally and then paint the face with the tile pattern you want on each layer? You can align the paterns within each face to the pattern you want.
8"cmu wall and 6" cmu wall
Sun, Aug 9, 2009 at 10:49:28 AM
Tall Objects Above Cut Plane: Bleachers
Wed, Aug 20, 2014 at 10:16:06 PM
View "Breaks"
Tue, Mar 5, 2013 at 10:17:52 PM
How do i make a foam wall with repeating vertical reveal
Sat, Nov 18, 2017 at 10:50:48 PM
Scheduling Curtain Wall Components
Mon, May 5, 2008 at 2:10:46 PM
Page generation time: 1.3513
